Hi
Avid Juicy five brake levers:
My front brake lever is not returning to its normal position once compressed. The caliper is fine, and the brakes are not dragging. So when I pull the brakes, the lever is really slow to return to its normal position, almost like the piston inside the lever side is getting stuck.
I have bled the brakes, made no difference.
Any idease?
Have you tried fidlling with the reach adjustment scrww in the lever? Try a few different settings there and see if it makes a difference.
