Before i go off to my LBS, I was hopping that you guys could assist me with a problem that i have with a strange sound coming from my frame everytime i stand or go over a bump. It's a loud snapping sound, i have checked every where and nothing is broken Smile . I am not sure if it is coming from the saddle, seat stays or seat post.
The bike is the 2009 Roubaix Pro
I have the 2008 model of the same bike and have the same noise.  Have sent the bike to the LBS on two occassions to have it checked out and both times and bike has come back with a clean bill of health.  The LBS have also checked for cracks - none.
I have therefore assumed that the noise - which in my instance comes from the fork area - is caused by the Zertz (elastomer inserts).  This is only a hunch.
You guys should be contacting the agent at least about this. get it in writing there in nothing wrong with the cracking sounds. otherwise, it fails outside warranty but the problem started when new and you loose out.
My guess is the agent will want to see the bike themselves and investigate
This question seems to come up a lot with carbon frames.
The usual reply from the bike mag Q & A's is that carbon frames can amplify and transfer noises, which on other frame materials would either never be heard, or would be easy to pinpoint.
Creaky saddle bolts can sound like BB's, cables rattling can sound like headsets. etc.
Hopefully it's nothing serious - good luck.
A bike shop owner recently PM'd me about a similar problem. I suggested that all (except for those that don't) mysterious noises emanate from the BB. He discovered that the aluminium BB shell had broken loose inside the carbon frame.
Why not try and eliminate all the variables. If you can re-create the sound at will it is a question of:
1) Doing a wheelie over the obstable to eliminate the fork and headset.
2) Riding with your feet off the pedals over the obstacle to eliminate the BB, cranks and pedals.
Info like this will help your bike shop endlessly. So search for a creak can take several hours and no-one seems to want to pay for such a search.
Let us know, it sounds as fascinating as cracks and creaks can possibly be.
