Guys, iam building a Weight Weenie road bike and need some advice. Below is my current set up,however i want to get the bike into the mid 5.5 to 5.7kg range. Furthermore i dont want to break the bank and dont want tubbies (i know i can easily shave off +-200grams)
Giant TCR Advance Team 2008 T-MobileGRAMS
Rear derailleur (double)181
Front derailleur (braze-on, double)72
Rear skewer KCNC24
Front skewer KCNC23
Rear brake caliper (w/nut) KCNC82
Front brake caliper (w/nut) KCNC82
Cassette (11-23T, w/lockring)174
BB (English threads)100
Crankset (172.5mm arms)635
Chain 210
Shifters/brake levers (pair, without cables)420
Wheels Mavic R sys premium1350
Giant TCR Advance Team 2008 (Small) ISP1245
Fork 340
Handle bars EC90 42cm187
Stem 90mm110
Cables Nokon120
Tires Conti Supersonic310
Tubes Conti Super Sonic105
Headset 42
Spacers Carbon9
Handle bar Tape   BBB Carbon Lite38
Misc grease, etc25
Saddle Sella SLR Carbonio137
6021
All components has been weighed other than the brake calipers as i have not acquired a set as yet.
Sorry i havent included pedals, When you buy a bike you dont get pedals with it.Big%20smile
But i do ride with Look Keo Carbons didnt still worry to weight them.
Shimano Dura-Ace, i was thinking of getting maybe Campag Record iam not a fan of Sram.
Also would a Sram Red Cluster work with the Shimano Groupset ?
It should do the spacing is the same. Mike bike is 6.6kg with red before I put on the 404's. That is with the mavic ksyriums SSC... With pedals though..
I used to ride record but moved over red in Dec and love it..
Sorry i havent included pedals' date=' When you buy a bike you dont get pedals with it.Big%20smile
yes but real weight weenie bikes are complete as you would ride them. Look at the new Speedplay at about 68g a pedal.
Ooh, those speedplay pedals are beautiful. Dont expect to do that much mileage on them though
WHY???
Hey Mak, sounds good
But I think you'll find a few of the things you have listed are spec. weight, and will in reality be a lot heavier.
Tyres for one, manufacturer's often quote the spec. weight of the tyre as the weight once the tread is completely worn down.
A Dura-ace crank is closer to 700g,
and brake and gear cables will be around 200g
I could be wrong, and you might have weighed everything already!
Aim for 6.5kg - that is still very light!
under 6kg, you looking at a R75,000 bike!
carlo_sg2009-01-19 04:54:48
Hey Carlo, most of the items has been weighed, The Dura-ace crank is not 172.5mm but 170mm thats why its 640g
I took the weight of the Conti supersonic tires and tubes off the website as iam still getting a set so not exactly sure of weight.
Will have it Weighed once its fully assembled though.
I have noticed that the weight quoted by manufacturers are slightly off.
