wtf, is the Spark aimed at monkeys??? Can't ppl figure out how to use the controles without those stickers?!?!!? It's not a f'ing Boeing, omg...Marius2007-02-13 03:21:55
They're claiming it to be so light & fast thet I'm surprised there isn't an Eject button on it as well... or is that on the right side? Wink
Nah, if it's that fast it should have one of those parachutes that comes out the back to slow you down ha ha ha haLOL but that might be a bit hard on the sub 1kg frame and snap it in half hiehiehieLOL
Marius2007-02-13 03:25:15
Buckshot, correct. Downloaded the April issue last night.
The easiest way is to do a screenprint and dump it into paint. Then cut out the part that one wants and save it as a jpg or gif file.
Marius, according to the article the bike weighs 11.2 Kg's (24.6 lbs) excluding pedals.
The Thug2007-02-13 03:44:47
ja for someone who wants to have the lightest full sus mtb on the market - thats a lot of lever up there on the bar, giant should just copy the bike and leave the lever off and then claim "lighter than scott" Big%20smile
The Frame is Carbon composite
Drivetrain is a mixture of X0 & XTR with Juicy Ultimates
Wheels are DT Swiss XR455
Fork is a Fox F100RL  (shame not even a terralogic)
Shock is a DT Swiss
Rock.....yeah, true true........what is it and why is it so special tho?  Shifters?  Didn't really look in detail.....someone save me hitting the back button and let me know!!Ouch
think  it might be for the shock yeah?
Saffa_G2007-02-13 03:57:47
The X0 triggers are on the same lever as the Ultimates (or the other way around).
The go / stop lever works the DT Swiss shock and has 3 settings....... Lockout, Traction Control & All Terrain  (sounds like a bleeding Range Rover LOL)
See the SRAM X.0 doesn't clamp over the bar but straight into the bottom of the Ultimate brake lever. Do they still give you the option of a bar clamp?... bit sh*tty if you change brake levers Confused
