DA 10spd hollow crank: crank bolts torque settings
Follow the procedure in the figure.
1, 2 Use the special tool TL-FC32 to install the right adapter (counterclockwise thread) and the left adapter (clockwise thread).
Tightening torque: 35 - 50 N?m {305 - 435 in. lbs.}
3
Insert the right crank unit.
4 Set section A of the left crank into the axle of the right crank unit where the groove is wide.
(Insert a spacer when installing the FC-7803 left crank unit.)
5
Use the TL-FC16 to tighten the cap. Tightening torque: 0.7 - 1.5 N?m {6 - 13 in. lbs.}
6
Push in the stopper plate and check that the plate pin is securely in place, and then tighten the bolt of the left crank arm.
Note : Each of the bolts should be evenly and equally tightened to 12 - 15 N?m {106 - 132 in. lbs.}.
I have scanned their website and the technical doc's but can't seem to find any mention being made of these torque settings, or am I blindWacko
I am looking for the torque settings of the gear fixing (5) bolts on the crank and not the bolts on the left crank arm.
