Sounds like blown seals.
Take your shock to your LBS and ask them whats wrong with it, buy the right parts and get some suspension oil. Then head over to the corect fox tutorial and give it an overhaul yourself.
Take it to your LBS and ask them to send it to Fox for repairs. Ask your LBS to let you have a loan shock in the meantime. If your LBS is any good they should be prepared to lend you a shock while yours is repaired.
