There was a thread a few weeks ago about a frame repair. I can't remember whether it was an aliminium frame. The repair looked very professional.
Hacksaw, cut the tube all the way through. Get a small piece of alloy turned to size, pull the frame apart and slide the brace into it. Weld it, slide the other side of the frame over the crack and weld again. The welding shop that fixed my frame is VERY good.
Fixed my broken frame like that a month ago, and it's probably stronger than it was before.
I had an old mtb welded that cracked right trough on the chainstays. The guy from the weld shop welded both sides to reinforce it. He the smoothed the welding with steel putty and I resprayed it. Looks as good as new and its been lasting for a while now.
Fixed my broken frame like that a month ago' date=' and it's probably stronger than it was before.
sounds pretty maverick......
have you posted any pictures?
Hacksaw' date=' cut the tube all the way through. Get a small piece of alloy turned to size, pull the frame apart and slide the brace into it. Weld it, slide the other side of the frame over the crack and weld again. The welding shop that fixed my frame is VERY good.
Quite true, your frame fix was probably the simplest but yet most effective fixBig%20smile
It wont work on this frame though, the shape of the frame is not round. I agree with JB, the frame is toast. the cost of fixing it will buy you a very nice secondhand frame here on the hub or a not too shabby new frame. There was a red merida frame going for R1200 not too long ago.
