Ok today i decided to try out that slime every1 has been talking about. But i have a problem, the tubes on my MTB uses the same valve as those used on the racing bike. I cant take out the valve to inject the slime into my tubes, what should i do?
Those are presta valves and probably solid ones
Just check them carefully to see as with some you can unscrew them if you look carefully to see if they are 2 piece but you will prob see the valve stem is a solid moulding so you wont be to add slime to those tubes.
I had the same problem so I bought 2 new presta slime tubes (these have the slime already added) and used my 2 original tubes as my carry spares
They will cost you in the region of about 85 rand each its far easier than trying to find tubes with 2 piece presta valves then buying the slime then trying to get it into that tiny valveBig%20smile
OK so tube is out.... Right take a pair of pliars....
1 Take off the little rounded piece off the valve ie you unscrew it to pump up your tyres....
2 Now grab the little piece that is loose in the valve, as it can fall down the valve
3 Be carefull and catch it through the tube, its long so shouldn`t fall out completely and get lost inside the tube. So pinch it through the tube
4 Pump in your Slime
5 Slide thingie back into valve
6 Screw round thing back on
7 All done and BOB is your uncle....
Now go play and practice
By the power of grayskull but that seems tricky. Thats way to much effort for me. But to make complicated things easy i quickly grabbed Mr. Bosch ....
 .... and converted my presta to a fat one. Within few mins my slime was in and ready to go. :)
  Quote
Pleasure so now you can support me when I have a BIG OKO special on soon keep?watching the forsale section
Oooeeeee this happening again?
  Quote
  Quote
Pleasure so now you can support me when I have a BIG OKO special on soon keep watching the forsale section
i think he's an official oko rep now. at least he babbled something about it here a while back.
