mine did something similar a while back, I thought it was the batteries and replaced them and still no luck.
once you replace the batteries in the strap you have to relearn the code of the strap to the computer
just check in the book, it will tell you how to do it.
The HR on my PT (non coded) also broke. Nochain had the same problem. Design problem, imo.
I also have a coded PT, never had any problems with its HR.
