coil.
Only say that cos I have yet to see a serious gravity bomber use an Air shock.?
A few things spring to mind:?
Coil for more linear travel vs the non-linear nature of an air shock.
Air shock doesn't bottom out easily, but blows through it's travel a bit faster than a coil
Air shock seals are under higher pressure. Maintenance?
Air shock is lighter.
Compression response easily tuned via external valves, and air pump. On a coil shock, you have to swap coils.
cant think of others now
Capricorn2009-07-21 12:02:15
hey Louis :) been keeping better. damn cold. Again. 3rd time in 3 months. As I told DHK earlier: it's getting really old really quickly :(?
Really dont like the lameness having a cold sometimes creates. Could barely hold onto my bike today. And for the damn mech to give sh*t to the point i lose the bottom 3 gears and turn my pedals into glorified fans. :(
Got a new chain and some jockey pullies. Hopefully that and a rear mech cable tension check will fix it. ?Wanna hit Tokai again this coming weekend, but the weather looks like it's gonna bail on me :(
klapperkop hey? lucky sod. :( looks a decent enough track that. U should make up a short clip of you ripping it up.
renewed the jockey pulleys, changed the chain, shortened it abit as well, but the damn chain still jumped off that first pulley. I think my mech is stuffed. Have an X.9 on order for hopefully Friday.
not tomorrow. sat or sun rather. just hope it doesnt bloodywell storm. oh and if u go, take some extra thick padding with, and maybe a spare mech. It's really gnarly out there...
