Um, stoopid question, sorry.
How do I adjust the air pressure on my fork (Tora 318) and what's a good psi value for my weight (60kgs) ? I have fiddled the rebound till I am as happy as I can be, but I am starting to think that with an adjustment to the pressure I will see a handling gain.
The 318 could be either, if it's an air shock there'll be a schrader valve under a dust cap on the top of the left leg. Remove dust cap, add air. If no dust cap then it's a spring, and you'll need to get a harder or softer one. As for pressure, set it up for 20 - 25% sag and take it from there.
