Help
I want excel to help me organise the first 3 of a category, using the time they finished.
Let say
Mampara came in at 2:05:03
Mud Dee came in at 2:10:30
Holy roller came in at 4:10:15
Jules came in at 3:05:59
all of them are in the same category, how can I tell excel to sort them when all the results are mixed.
XTC OKE2009-09-08 04:35:00
=if(isna(VLOOKUP(D6,'Entry Details'!$A$2:$C$478,2,FALSE)),"",VLOOKUP(D6,'Entry Details'!$A$2:$C$478,2,FALSE))
or if you're using Excel 2007 (I assume you're not, but I had to test it on my PC):
=IF(ISNA(VLOOKUP(D6;'Entry Details'!$A$2:$C$478;2;FALSE));"";VLOOKUP(D6;'Entry Details'!$A$2:$C$478;2;FALSE))
Cheers,
Andrewandrewc2009-09-07 12:30:14
I can't see anything wrong with the formula. What is it doing that you don't want it to do?
It will subtract the value in B2 from G6, but if you copy this formula to another cell, it will always subtract the value in B2, while the other cell reference will move relative to the original cell's position (as if that makes any sense).
Post what you need it to do... (or what it's not doing).
Cheers,
Andrew
Im using a macro to subtract the current time from an (vaste tyd)
So when I enter a number it calculates the time, but on the cells that I dont enter a number there is alot of ######
andrew, you dont know of a function in excel that can give you the 3 fastest times in say a category? or can one use conditional formatting?
andrew' date=' you dont know of a function in excel that can give you the 3 fastest times in say a category? or can one use conditional formatting? [/quote']
I think you are looking for
=Percentrank
Guest Agteros
It will subtract the value in B2 from G6' date=' but if you copy this formula to another cell, it will always subtract the value in B2, while the other cell reference will move relative to the original cell's position (as if that makes any sense).
Cheers,
Andrew[/quote']
take the $ signs out.They indicate that the refeference to the cell should not change when copying the formula... =G6-B2
