I know the BCD is 104mm, now what rings other then shimano work?
Im looking to use 1 ring at the front and 9 cogs at the rear.
What would be a good ratio to use? I was thinking a 38 in the front?
What do you think?
Blackspire and Middleburn both make XTR compatible rings. Available on CRC. I think BBB and KCNC may do them as well.
XTR has 3 different BCDs, one for each ring, so it'll all depend on which ring you're using.
