I put the rotors on my fucrum red metal 5 centre lock today,and noticed a slight clockwise /anticlockwise 'play',its a very small movement.Is this normal?
It may be play in the rivets between the alu body and the steel disc, I'm assuming you can feel this play when you apply front brakes? It can also be a slight movement of the pads in the caliper...
