It appears as if the battery pack has a built-in charging circuit then' date=' because that's just a normal 12v DC tranformer...
2x Li-ion is 7.2 or 7.4v.
You can use a 12v DC adaptor then. Any amperage above 1A will work. Just check the polarity adjustment!
Regards
Johannes
So can I use the Ellies one I bought? Thanks again for the help Clap
  • Replies 39
Quote [ If you cannot find a replacement give the old one to an electronics
guru. Power supplies are not that hard to decode. The flashing lights
in the light that indicate charging/full, suggest that it's a dumb
charger - the brain may be in the light? ]
The brain is in the light?
Cycle Fan, did you manage to sort your charger out in the end?
I am picking up on this thread rather late, but I just wanted to add my R0.02 on the dangers of using any old charger to charge Li-Ion batteries. In case anyone else reading this thread decides to try this recommendation.
As already mentioned, Li-Ion batteries will get damaged by using the incorrect charger, but more importantly, there is a real risk of your batteries exploding and setting your house on fire (or worse), if you use the wrong type of charger.
Li-Ion's require a specific charging algorithm in order to prevent nasty things like internal short circuits inside the battery, which can start a chain reaction with a not-so-happy ending.
Bottom line: Only use a properly spec'd Lithium Ion charger to charge Lithium Ion batteries!! Same applies for Lithium Polymer.bradjackson2009-10-14 06:07:47
Agreed. The thing is that in this case, the current limiting and temp sensor is with the light and the charger is nothing more than a mains transformer. So - you can use pretty much any "power supply" - as long as the voltage is correct and it can supply the current required - in this case 800 ma. In fact you could charge this light off a car battery!
  • 6 years later...
Hi Jo, I couldn't get a decent enough pic of the sticker so I emailed you the wording. Here it is again:
AC DC Power Supply
Class 2 Transformer
Model No: MD242-120085
INPUT: AC 120V 80hz 24W
OUTPUT: DC 12v 850mA
Polarity: -   -(�------- +
Thanks again for the help, really appreciate it!
Hey dude, I'm in the same boat.... well, not exactly - I didn't FRY mine haha, but I did lose it.
I have a variable charger, but before I plug it in, I need to know the polarity please.
You have pasted a polarity 'thing' but I'm not sure how to read it (and I'm not a betting man...)
