Maybe someone can help, I have a Polar CS200, I am changing batterries every second day. When it is switched off it still sounds as if it's transmitting, and that is obviously why its chowing the batteries, why is it transmitting when it's off have i stuffed up a setting somewhere?
Dont believe it's a setting issue. I got the same unit, was having problems with my buttons not working, sent it to Polar SA thru my LBS. They replaced the unit after nearly 3 years!!! Blew my mind..... Give them a try.
