Hey im trying to remove the bottom piece of my headset off my forks steerer, but its on increidably tight, I just lubed the whole thing now, could anyone help me on how to pull that thing off?
Any help would be much appretiatedSmile
You need a race puller in order not to damage the fork crown. Just take it to a shop and they will remove it for you.
http://www.bikeparts.com/pimage/BPC106894.jpg
You can remove it with a hammer and a punch/screwdriver.
Turn the fork upside down and place the end of the steerer on a block of wood or some other surface to prevent it being damaged.
Use the hammer and punch to alternatively tap either side (front/back) of the race until it falls off.
If you've got a big enough bench vise, you can use that instead of the punch:
http://www.sheldonbrown.com/headsets.html
