Is there any way you can change the strength of the pull on the arm of a LX derailer? I want mine to pull back tighter to take up the slack in my chain.
The spring is fixed - i.e. you can't change its tension, but if you're do want to tighten things up, then there's this thingy callled a B-tension adjustment screw..
don't know how to explain exactly where it is except to say you access it from the rear of the derailleur and it faces onto the little bump on the dropout on the frame. sorta behind and above the cable tension barrel adjuster in the picture you've given.
Give that a few turns. it will make the derailleur sit closer to the cluster
The spring is fixed - i.e. you can't change its tension' date=' but if you're do want to tighten things up, then there's this thingy callled a B-tension adjustment screw..
I found that screw, but do I want to pull the derailer up or further away from the cluster? by the looks of things, loosening the screw will pull the derailer up, and tightening pushes is further away
is your chain the correct length?
Yep, tight but not too tight, the length is so that the derailers arm is perpendicular to the ground in my "fast" gear (I ride downhill) becasue thats where i found most of the pull on that deraileur arm, as apposed to it being higher or lower than 90 degrees to the ground.
