Where to find a decent valve extender?
I find that most valve extenders do not seal nicely.
What I'm looking for is the type of extender that can screw into a valve with a removable core. In other words, remove the core, screw in the extender, screw the core into the extender if it doesn't already have one.
Does such a product exist?
What is your experience with valve extenders? Which ones do you use/recommend?
I have some spare brand new valve extenders at home, will check and see how they work (still in plastic so not sure if they are the type you are looking for or not). Will check this evening, if they are what you need, you can have a set...
