As you might know the Mavic Freewheel body uses a nylon bush. If this starts wearing out, which it does and it will again and again, you have three (four) choices.
a) Buy a new freebody since Mavic does not sell the bush separate
b) Buy an aftermarket bush which will wear again
c) Throw the wheels away - call me
d) replace the bush with a bearing
I've gone for option B and then D. My freewheel now has ceramic bearings with less drag and (very important) less maintenance!!!! What a pleasure. I can now eventually enjoy my Mavic wheels without fearing the next loud screech as I go down a hill. Let me know if you have this problem I might be able to help.
This advertisement was paid for by the 'Touch me on my studio' foundation, helping to educate 'slow' people.
You replace the nylon bush with a ceramic bearing. This means that when you freewheel you are spinning a bearing and no running a bush over the hub body. The kit is sold with everything needed to do the conversion, even a tool to size the hub body if you are in the fortunate position to have no wear. Mine worked out to about R340 where as a new freebody is ~R500. The guy who makes these are in the states and I had somebody bring it over for me.
