Canaan frame hairline crack
mojo2
 Share
Have any of you had a problem with Canaan frame cracks, i did read on the net they put a triangle on the seat tube to make them stronger because they cracked there (2007 frames) but that is exactly where mine cracked, on top of the triangle (on the welding) do you okes think Mongoose (omnico) will replace the frame under warranty seeing they have lifetime guarantee but i am the second owner
Link to comment
Share on other sites
Guest Big H
I may be mistaken but lifetime guarantees are only applicable to the original owner. Maybe if you still have the original receipt you may swing it.
Link to comment
yes, if you are the first owner, they will (should replace) If your not, then I doubt weather they will.
Link to comment
 Share
