Does anyone know where I can get a list of MTB frame weights? I want to upgrade my Merida HFS 3000d alu frame to a lighter carbon frame. Think my frame is 1450g, looking for something around 1100g.
Will you please list a frame weight that you know on this post. Size medium please, i think that is the size most manufacturers use.
Merida 0.nine weighs 930g (960g for BB30 version)
cannondale flash 950g
Then I guess my Be-One at 1590g is a bit heavy.
There is a Schwinn in classifieds for 1350g odd grams.
By losing 300gr you will also be losing about R10 000.
have you tried the weight weenies listings ?
They are being updated to include newer frame weights
Only frames I know of are:
Cannondale flash and merida o nine as mentioned
Giant WAS around 1,1kg for the medium in older white/blue, unsure of newest weight.
Scott scale top model RC with the ISP is under 1kg as well.
Im guessing most carbon mtb hardtails in medium are about 1,2kg
Ha Ha you must see our weight debate on Rant and Rave.
Depending on your budget, I dropped more weight with about R3k changing pedals, bars and stem.
