For those looking for a top notch, sleek, non bulky, quality bibshorts for the new season, consider the new Castelli active cushioning (AC) pad bibshorts. Special high tech features include the following;
ACTION fabric with PROSECCO treatment- a hydrophilic treatment which causes water droplets to spread out over a larger surface area allowing for quicker evaporation
ACTIVE CUSHIONING PAD-the AC 37 pad is a feat of science which features NASA designed Comfort Tempreture technology to keep the pad at a constant 37?C. The pad uses a triple layer, thermowelded multi density foam for seamless comfort and progressive damping, making sure the cushioning always cushions. Each of the three layers have additional perforations which provide even more airflow and breathability.
GIRO+INJECTION moulded silicon leg gripper- rated one of the best around
The AC pad bibshorts are available for both men (FREE & CRONUS) and  ladies.
VIZIO ladies shorts-uses the legendary ladies specific YPRO3 pad and GIRO silicon leg gripper.
For more information check out the Castelli website. www.castelli-cycling.com  Look out for the summer 07 collection.
The SRP of the Castelli bibs as follows;
AC pad
CRONUS........ R1250. budget version of the FREE
FREE .........R1600...Top of the range
KISS pad
WICKED.......R800...best value for money
ladies YPRO3 pad
VIZIO ladies shorts.....R765
Most LBS will gladly order the bibs for you and delivery time is normally by the next morning.
Both the CRONUS and the WICKED have the new BUCO strapes that eliminate fabric bunching. The FREE uses normal stapes but far less material with a low cut in front. Not good for those with beer bellies.
