Can anyone maybe help or point me in the right direction. I am looking for a coin rechargeble battery. ML2032. Must be rechargeble. I cannot seem to get anyone online in SA that sells this. I have tried at my local chemists but no luck. Thanks anyone :unsure:
Are they not the ones computers use to keep their clocks running??????
Guest agteros
Interesting reading this....
http://www.realtech.co.za/realwiki.php?title=Coin_cell
Rechargeable variants
Regular watch batteries are not
. Rechargeable button cells are commercially available, but are not commonly used due to their inferior capacity or higher self-discharge. Also, watch batteries are usually used in low-power devices where batteries are replaced very rarely so there is no big benefit from using rechargeable batteries but higher self-discharge rate and lower capacity could make using rechargeable batteries impractical. Rechargeable
button cells were often components of the backup battery of older
as well as
computers. As of 2008 there are some commercially-available rechargeable watch batteries, usually intended to replace CR lithium batteries in devices with relatively high current consumption. An example would be the Telong branded ML2032 rechargeable battery.
At R20-30 a pop for non-rechargeables, and with them being readily available, and lasting quite a while, I'd love to know why the quest for rechargeables?
