Hi, my gear shifter broke the other day.
The white plastic part that holds the gear cable broke and the cable came loose. Can this part be fixed or replaced, or do I need a whole new shifter assembly?
Sort of the same thing happened to me the other day...I have Alivio Shifters (gear and brakes) Depends on how old your bike shifters are, if under 1 year, could be replaced under warantee, that is if there are no scratches or signs that you tampered with them :rolleyes: Mine came loose, Local bike shop couldnt repair, took it to shop of purchase, three days later: VOILA :thumbup:
...Depends on how old your bike shifters are, if under 1 year, could be replaced under warantee, that is if there are no scratches or signs that you tampered with them...
Nope, no such luck. They're pretty "well used"...
