what type of powerlink can be used on the xt 10 speed as am assuming that the sram 9 spd cant be used
I was told i had to use the snap on one that requires a tool to remove
is this true
sram 10speed link can be used , but it cant be removed by hand like the 9speed one . a tool is required. I would just suggest using a normal 10speed shimano pin ( buy a bag of them ).
Then you would have to keep breaking the chain every time you want to take if off, that is a just silly.
I remove my chain once a week!!!
Get the 10 speed Sram links, the can be removed using normal pliers.
You can also use a 9 speed link on a 10 speed chain. It is much easier to remove and can be done by hand because the link is slightly wider than the chain. But I would not recommend this for everyday use, only for emergencies to get you home if you can find nothing but a 9 link.
I used a Dura Ace 10 speed for a month or two but then it started jumping on the casette.
Shimano's attempt at a quicklink did not quite work and the stopped production on them :(
Only reason I wanted another one, it was so easy to remove, no tools needed!
Might have to try these YBN ones, you are the second one to refer to them Mampara
