You get this adapter to mount on the lower part of the fork:
http://www.cannondalestore.de/SHOP/200/8CM01.jpg
From Dr Cannondale or ebay
I used one for a while before I installed the Garmin 500 sensor on port chainstay
Thanks, Ive tried the rear wheel but no luck.
The manual says that 70cm is the max distance that that can be accomodated.
I have measure from headset to sensor on the bike and it is 80cm.
  • 3 weeks later...
i made my own mount that goes from the lower part of the fork over the disk and lets you mount your sensor there > will post a pic later, but alot like the adapter in that link... works a charm
