I managed to bend the RH brake lever (XTR 2011) last night. The levers are quite short and stubby and as a result its quite difficult to reach it now.
I'm going to try straighten it first, but in a worst case scenario....
Anyone know if the lever can be purchased and changed without to much hoo ha?
Have not had a chance to check on line if the levers are available as spare parts or if they can be replaced....
Looking at the lever assembly I suspect Shimano wont be selling any of the parts required separately.....
heat it up with boiling water before you bend it, that shimano aluminium stuff has a tendency to snap.
Fixed it for you :P
But yes your right it could crack / break if not done with some care
