Hi All
What replacement valves would you recommend? I have a Shimano Wheel set, i understand that there is a difference to what will fit on certain makes of rims, is this so?
Just popped in some American Classic valves and they are the best I've used. Their little o-ring seal works better than the "tapered block" or flat tapered seal types I've used before. Highly recommend them.
