Introducing the new Power2max FSA Gossammer crankset. The unit will retail below R10k and is expected to be available end of October/November.
Updated Features:
  • Right-Left-Splitting of Power readings
  • Compensation of temperature dependent drift
Other Features:
  • Change chainrings without calibration
  • Measure cadence without external magnets
  • Customer replaceable battery
  • ANT+ Compatible
http://www.facebook.com/Power2MaxSouthAfrica
www.power2max.co.za
Updated Features:
This used to be a big problem in South Africa (where you often get a delta of 20+ celsius.) It's good to hear they fixed this.
What's the MTB BCD? 64/104?
In reality it was less of a problem than some reviewers made it out to be.
The new calibration system of temperature compensation may however make Power2max the most accurrate power meter in real world conditions.
MTB BCD's are 104/64 or 120/80 in double.
Is this power meter available in SA and from whom? Can it be fitted to Campag Super Record crankset? Price?
Yes, Power2max is available in South Africa from www.power2max.co.za
Unfortunately it cannot be fitted to the Super Record Cranks. The Rotor cranks work just as well. I run a Rotor 3D Plus with Super Record.
They come in compact 110 BCD versions and standard 130 BCD versions. You can choose which chainrings to run.
Contact Andrew Smith on:
power2maxza@gmail.com or
081 540 86 85
  • 2 weeks later...
I run a Hollowgram crank.
Will I need to change to a Rotor or something else to fit this P2M?
Unfortunately yes. Power2max does not make a Hollowgram version at present. We highly recommend the 3D Plus.
