I upgraded my brakes today to a nice new set of SLX units thanks to TheV's great prices :-) The back brake started gripping like a demon after a couple of pulls but the front one feels a bit spongy and I have to apply quite a bit of pressure to slow me down. Do pads normally have to wear in over time or should they be good to go from day one?
If the brake lever feels hard when applied but the brake does not stop "sharp" then it probably needs to be bedded in, this is common with most new brake pads / discs.
The above can be fixed by doing a some firm braking almost to a complete stop from a highish speed (without locking the wheel), repeat this untill the brake action is sharp, usualy takes +/-10 of the above.
If the brake lever still feels spongy or not hard when applied then it is most likely air in the system and needs to be bled out.
