Rotor Q-rings
LOOK695
I see that Rotor is quite popular amongst mtb's here on the hub. Are there any roadies using them and do they work? Any hassles with shifting on the front?
Link to comment
Share on other sites
I use them on my 695 and they are awsome , 10 pick up's on the big ring so
no shifting issues .
What groupset are you running. I am using Campag 11speed and am slightly concerned about compatibality
Link to comment
I use the 2013 Red , 10/11 speed chain rings are much the same .
They do make campag specific but that is BCD related rather than
10/11 speed .If you buy the LOOK chain rings you use one set for both .
Link to comment
There are specific rings for Campy. I have heard they are a bit soft though. Burry's dad runs the Specialised store that stocks them in your area. I know of one hubber in Cpt that was running them with Campy and he had no issues.
Edited by MCipollini
Link to comment
Thanks. Have they benefitted your cycling in any way? Where is the best place to buy them?
Link to comment
Soft as in wear and tear soft or flexy soft
Link to comment
You can fit them to your existing Campy cranks. You do not have to fit the Rotor 3D cranks. Rings should be between 1500- 2000 grand last I asked about them.
Link to comment
Wear and tear heard from one lbs. Chat to the Stander's and get their opinion.
Link to comment
If you keen I bought multiple ratios , got a brand new set 39/52 you can have at a steal .
I assume this would be shimano?
Link to comment
