Edge wheels
b_andrews4
  On 1/8/2013 at 6:39 PM, b_andrews4 said:
Hi all
Does anyone own a set of these wheels? I'm losing at their 50mm carbon clinchers.
Any help or advice will be much appreciated.
Barry
I used to have a set of them, but tubbies. AWESOME wheels, super fast, super light!
I have a set of the 50mm clinchers with the alu braking strip (50AC), the bearings / hubs in those wheels are the business. Definitely not the lightest carbon wheels around, but they're a good, strong, fast and reliable wheelset.
  • 5 months later...
If you are looking at the Edge wheels on the Hub, be aware of the following. These are not Edge Composite wheels that have changed their name to ENVE Composites. These wheels are Edge Design wheels from USA running on the name of EDGE Composite. It is not the same company
Guest Omega Man
Ok I could well be wrong but i have Edge wheels and it's my understanding they were made by ENVE composites. The name changed to ENVE. so Edge=ENVE.
You have the old Edge composite wheels :thumbup:
Edge changed to ENVE about 3or 4 years back.
Edge Design WWS-XR300
Aluminium road wheel set 30mm including skewers - The same as the lighter XR200 model, but with the added benefit of a 30mm deep rim for those slightly flatter stages.Price:R2350 S/N: WWS-XR300
Try Olympic Cycles Claremont Ctn.
Or.. If you can get hold of Willie Engebrecht, could assist you.
Prep yourself .. R 7000 upwards per rim...
Good luck
  • 4 years later...
Hi guys, I wondered if any of you could help me out here. I recently obtained SLR 300 Edge wheels not knowing that it had a Campang Free Hub. I'm running Shimano 105. Where can I Buy the correct Free Body?
Thanks!
