Hi, I have a new frame which has a press fit BB, a specialized as above. The question I have is can you get a BB or an adapter that allows you to fit a normal external BB Shimano crank, or do I need to buy a new crank as well?
Yes I use a 'normal' external BB XT crankset, it's just a different BB!
What he said
I went from ext BB to press fit BB on my trek, and just moved the crank over. No Problem
Specialized actually make adapters that they send with their cranks, but the pressfit BB's are stiffer and easier to use and way lighter than an adapter plus plate plus a screw in set of cups.
Did the same on my Trek - no issues.
Okay found this online at Buycycle - specifically for Specialized
Should have been delivered to you by now, correct ?
