I just sprayed the undercoat, sanded slightly with high grade w/paper, 2nd coat primer followed by three colour coats.
What happened. Come off again?
Yip, and the water paper with final coat (2nd) primer. It worked for me. Also "sanded" down between coats. Also depends on your paint "mix" and any overcoating must be avoided. Just spray one time.
My 2c worth and it worked for me.
I would not even use a filler primer if the surface has no blemishes you need to fill - just a straight epoxy primer.
You can also consider phosphating the frame before painting it - rusist has worked for me before - waterbased - spraying it on gives a better finish than using a paintbrush.
