Hi Guys, so after buying two multitools with k@k chainbreakers I ended up with two quicklinks in my chain due to a damaged link. Will this be an issue? Oh and I have found a decent chain breaker now! Not a multi tool, just a breaker.
I find my chain breaker on my multi tool to work much better than one of my friends "just a chain breaker".
One also has to use the right 'setting/area' in the chain braker (9sp vs 10sp) for it to work nicely
*I guess you'll see which is the weakest link now ^_^
Problem seems to be that the pin that pushes the pin out the chain is slightly too thick, sad as the manufacturer claims that it is a 9 and 10 speed breaker? We have tried it on both 9 and 10 speed chains - no luck Edited by martinsnyman
