When I ride off road over rocks or corrugation, my mtb keeps skipping and shifting gears at random (when I go over bumps in the road). I have a brand new chain on and had the bike at my lbs and they did some adjustments on my rear derailleur, but they did not fix the problem.
What to do???
  • Replies 40
Best way to solve this problem is run a uninterrupted gear cable housing from your shifters to the dérailleurs, this would mean opening frame ferules with a drill to fit the housing through. The problem on many dual suspensions that was clearly not thought through. As your suspension moves the places where gear cable runs open (without housing) is where the problem lies as it adjusts with your suspension movement. Just let the distributor know of your intention to do this as it may void the warranty but it is the only real solution.
Get a rear derailleur with a clutch system.
http://merlincycles-img.s3-eu-west-1.amazonaws.com/productImage_1280_1024_ffffff_image-jpeg/8578_shimano_xt_m786_10_speed_shadow_rear_mech.jpg
yes, a agree with the solution to the problem.
Lately i had some random skip (mostly on front ring, under some torgue) and found it to be my quicklink that was starting to show wear...replaced it and problem went away!
Just fitted one to my KTM 26er - works like a charm for chain suck - nothing - nada - not even an attempt at chain suck - even in the roughest of single track :clap:
I don't see a clutch derailleur solving the problem it only controls your chain slack better. This is cable tension related.
I also don't think it would, because my derailleur was tightened to the max. It only started skipping gears about a month ago.
Try replacing your cassette before you try anything else, you say you replaced the chain but not the cassette? I'm willing to bet it's that.
That was my best guess as well after I googled the problem.
What to do???
And this problem might cause a crash in a race...
I understand the logic to this but it's an expensive way to possibly find out that it's something else?
