The construction is completely different.
Some say the tiara will last longest, but is the heaviest.
It depends what you want tho. I ride a 105 because it was cheaper than ultegra, and I wasn't too concerned about weight. My broke friend rides tiagra, cause he spends the least amount possible
If you're just a weekend warrior, go for tiagra.... I'll probably do that next time around....
Most likely weight. I ride a Tiagra cassette on my Dura-Ace/Ultegra setup. Cheap and cheerful.
EDIT: That said, marketing plays a big role. I still run a 9-speed setup: SRAM 9-Speed chain, Tiagra 9-Speed Cassette, Dura-Ace 9-Speed front and rear derailleurs, Ultegra 10-Speed Crankset and Ultegra 10-Speed STI's and everything operates perfectly. Perfect shifting.
EDIT: I use a JTEK 'shift mate' to match the 10-speed STI's to the 9-Speed rear derailleur.
Edited by Smartie
Im not overly concerned about weight, more the cost. I need to replace cassette and chain on tri-bike (dura-ace) and road bike (105) as well as IDT wheel which is going to be an expensive exercise.
If they are compatable, then i think the Tiaga should do fine.
As long as the 'speed' matches, i.e 10-speed, you will be fine. You can even use a SRAM 10-speed cassette with no worries.
