Scott Spark 940 BB Problem
Pre-Loved Cycles
I had serious creaking coming from the frame...after all the above checks even replacing the bb it looks like it was just the adjustable BB height mechanism...(those oval inserts) ...i took it apart and cleaned all the grease off  the ovals and frame ...reassembled and my creak has vanished..remember to put it back the same setting high or low...unless you want to change settings.
I suspect that these ovals will require regular cleaning and it won't just be a one time cure.
Hi, I need help asap. My Scott Spark 940 is making a cracking, squeaking, breaking noise coming from the crank/BB unit when riding in dusty conditions and the harder I pedal, the worse the noise. Its making me and the people I ride with mad. Do anyone have any suggestions or has anyone had the same problem? I had it serviced at various shops and nobody has been able to find the problem. Thanks
Remove rear axel, grease shaft with copperslip, reinstall.
Let us know.... chasing noises is hard.... but rear axels often make noises that sound like it's coming from the BB - especially thru-axels....
  • 4 weeks later...
good day
i have the same problem with my 2014 scott spark 940 and it sounds like the bike wil be falling appart soon!!!
i have replaced the headset already after 4 months as the bearing broke and made the same noises!!!
now im worried that the bottom bearing is also broken i have done everything you guys said but still have the noise im taking the bike back to the shop for the 100th time and the bike is not even 6months old!!!
  • 11 months later...
I have the same noise and spoke to two guys with the same problem and it was the the crank hole that was a few mm out and scott replaced there frames,i must still go to the shop to see if it is the problem.
  • 3 months later...
I had the same issue after owning the Scott Spark 940 for 3 weeks...... Also my rebound stopped functioning. Could not adjust the rebound any more as adjuster had jammed....
