Shimano M445 Hydraulic brake not responding
kolaval
Right, eventually took the bike to epic sports (nice guys there!).
It seems my brake is leaking, and they suspect its at the O ring.
Is this something you fix or replace?
If you need to replace is there a newer model brake that will fit?
What's the cost of the repair by the bike shop?
  • Replies 39
  • 5 months later...
Hi all,I owe that bike now,and found the problem,also new at this,so hope you can assist.
Tried to bleed it,then saw that it leaks at the seal between the top cover and reservoir.
Is that something one can buy loose and replace it?
