Hi.
Anyone know who's the best local stockist of disc brake mount adaptors? I know I can get from the likes of CRC but would like to attempt at local first...
Specs are: Front-Avid IS mount 180mm rotor
Rear-Avid IS 160mm rotor
They for the Avid elixir 1 onto a GT Avalanche frame...
All suggestions appreciated. ..
Thanx
Hi.
Thanx
hahaha....at least im not the only one that had this problem....got mine the other day. There are quite a different sizes for the adaptor, so make sure you get the right size. Mine also went onto a GT frame. LBS should have them
Also the 2 mounts you are looking for are identical, 160mm rear is the same as 180 front, for some reason they still label them as front and rear even though they are identical. So if a shop says they only have 2 180 fronts or 2 160 rears they will do the job.
I actually dont think they are identical. But i could be wrong
Edited by Fabian46
They are identical.
I have a whole bunch at home. I can check tonight but im sure I have.
PM me if you want me to check.
They are identical.
They are identical...lol
My front isnt the same because the LBS used the adaptor...and then some spacers! Didnt realise that.
Edited by Fabian46
