posting pictures using S4 lte
Tayyib
I cannot work out how to post pictures using my Samsung s4 lte....is it just me or do I need to load pictures to a computer and from there to the forum?
Please help as this has become very frustrating.
if you're browsing via a browser, you have to use the full version and not the mobile one. Scroll down to the bottom you'll see there's a link that says something along the lines of "Use full version" - from the on the thread - use the "More reply options" .
shout if it's something else.
Doffs cap at Uni, a damn sight better attempt to help than mine :blush:
Doff's cap at Uni, a damn sight better attempt to help than mine :blush:
It's the IT slave within me  :ph34r: but what's a Doff's cap?
I was using just the standard browser in incognito mode...I have tried the full version but never seen the 'more replies' option....will have another look
is it worth/better downloading tapa talk? Will it increase the browsing and posting experience. I spend to much time on the hub. So want the best possible view .
I have found the page where I can upload files...However when a file is selected it does not upload to the post, even though it shows that a file is loaded...This possibilly due to the file size.and if so how do I compress the picture.?
Step 1: Select the file you want to upload - file size maximum is 2MB
Step 2: locate the file and it will upload it. You then need to click the "Add to post link"
Step 3: it will show this in the post reply section
if that doesn't work. press Alt F4 and go back to work  :ph34r:
Step 1: Select the file you want to upload - file size maximum is 2MB attachicon.gif1.png Step 2: locate the file and it will upload it. You then need to click the "Add to post link" attachicon.gif2.png Step 3: it will show this in the post reply section attachicon.gif3.png  if that doesn't work. press Alt F4 and go back to work  :ph34r:
thank you...2nd portion of step 2 is where I was going wrong.
