Hope pro 2 hubs 2010
nicbrick
Hi guys.... I need advice!! Can hope pro 2 hubs with skewers be converted to a 15 mm thru axle front and 12 mm thru axle at the back..... Old wheels on new bike... Thanks
I am about to do the same thing, my research indicates that you need an X2 conversion kit for the rear which also converts a 135 to 142. A different conversion kit is required for the front checkout www.chainreactioncycles.com . Keen to see how you go.
