Light for Aero Seatpost: Suggestions Please
leaboy
In short i took a 20mm pvc pipe. Cut 2 grooves in - sprayed it black. It hooks in underneath the seat. Then you secure the blinder light to the 20mm pipe. Does not look bad. Ill post some pics when i get home.
thanks @JoeZipp, look forward to trying your solution before taking it back to the shop to replace
10 minutes of filming? Doesn't seem much evidence unless it loops and you remember to switch it off after you are hit from behind?
Edit: Added review from  Bike Radar
Also ride is saved in 10 minute sections so whole ride is savable.
smart looking light, how long did it take to get into the country?
import taxes high?
I got it at John O Connor Cycles.
Try your closest Giant product stockist.
Yes
"The Fly6 compresses footage into an AVI format, and the timestamped video segments are broken up into 10-minutre clips (around 650MB per clip). While this is done to help break up segments into smaller chunks, it can be slightly overwhelming and time consuming to sort through a huge list of video files in an attempt to find the 30-second clip you want. Once the 8GB MicroSD card is full, the Fly6 loops back and records over earlier footage."
and...
"That said, the Fly6 is not overly expensive, and does combine both accesories into a neat package. Not only is the unit making you visible on the road, it is also recording your friends' best pain faces as well as aggressive drivers."
