Scott mc 50 rear shock
clark.grill
I just bought a second hand Scott mc50.i would like to know what pressures i should pump the rear shocks.I'm relatively new to all this.any other tips and hint would be awesome.I ride some off road but nothing heavy mainly used as a commuter.thanks in advance.
there should be a guide on the shock body
Remove all the air, pump up the positive air first and then the negative air.
If you don't come right let me know, as I have a MC30 which uses the same shock and I can send you a picture of the air pressure guidline.
Air Settings
    soft        std        tough
Kg    +    -    +    -    +    -
82    9.9    5.3    10.4    5.7    11.0    6.1
83    10.0    5.4    10.6    5.8    11.1    6.2
84    10.1    5.4    10.7    5.9    11.2    6.3
85    10.2    5.5    10.8    6.0    11.4    6.4
86    10.3    5.6    10.9    6.1    11.5    6.5
87    10.4    5.7    11.0    6.1    11.6    6.6
88    10.6    5.8    11.1    6.2    11.7    6.7
89    10.7    5.9    11.2    6.3    11.8    6.7
90    10.8    6.0    11.4    6.4    11.9    6.8
91    10.9    6.1    11.5    6.5    12.0    6.9
92    11.0    6.1    11.6    6.6    12.1    7.0
    soft        std        tough
Kg    +    -    +    -    +    -
82    144    77    151    83    160    88
83    145    78    154    84    161    90
84    146    78    155    86    162    91
85    148    80    157    87    165    93
86    149    81    158    88    167    94
87    151    83    160    88    168    96
88    154    84    161    90    170    97
89    155    86    162    91    171    97
90    157    87    165    93    173    99
91    158    88    167    94    174    100
92    160    88    168    96    175    102
The alignment didn't come out well, top table bar, bottom psi.
Another tip, you need to have your TA lever in full travel mode, else you are only adjusting the main chamber and not the piggy back
