Tubbies - reduce pressure when not in use?
NotSoBigBen
It was mentioned to me recently that tubbies should not be left at 'full' pressure when not in use as it may actually pull a wheel 'out of true' due to the high pressure ..... being new to it I wondered if that is really true?
Seems like an urban myth to me .......
Shouldn't happen if the tubbies have been cured in a mouldy dungeon for at least a quarter of a century. As tubbies should be.
Drop pressure immediately if you leave them in the sun, like in the car
Otherwise, mine loses air naturally with time, in between use
BS - unless the wheel build is dodgy....
