Giant 142x12 thru axle conversion
BattleScar
  • Replies 40
Can this conversion be done on the 29er Anthem X1 2014? Running Wide Lightnings with the QR setup, which I take it will also need to be converted with some sort of kit
if the rear hub is disc 225 then i believe it can be adapted to 12mm. Ā
Anthem rear can be convertedĀ
Ā
in fact here is full list of what bikes can be done
Ā
all about the Giant 2014 MTB 12x142mm Thru-Axle Dropout Kit w/ Derailleur Hanger
Compatible with:Ā
  • Anthem 27.5 - 2014 Ā
  • Anthem Advanced 27.5 - 2014 Ā
  • Intrigue 27.5 - 2014 Ā
  • Lust 27.5 - 2014 Ā
  • Lust Advanced - 2014 Ā
  • Obsess Advanced - 2014
  • Reign - 2015 Ā
  • Reign Advanced - 2015 Ā
  • Trance 27.5 - 2014 Ā
  • Trance Advanced 27.5 - 2014 Ā
  • Trance SX 27.5 - 2014 Ā
  • XtC 27.5 - 2014 Ā
  • XtC Advanced 27.5 - 2014 Ā
12x142mm rear thru-axle dropout conversion kit For use with 12x142mm RWS rear thru-axle Includes: Drive and non-drive side dropouts Derailleur hanger Attachment boltsĀ
Ā
Ā
Ā
Compatible with:Ā
  • Reign - 2015 Ā
  • XtC 27.5 - 2014 Ā
Ā
Ā
Thanks, however I don't see the 29er listed there
Hi guys, I've got a 2015 Giant Trance 2. Is it possible to convert to rear through axle with the stock Giant Tracker Sport rear hub? I've called around and have been told by some its just different inserts on the hub whilst others say the hubs are not compatible?
Ā
More than likely the parts will not be available to do this. So you will need a new rear hub.
Cheap option would be a Novatec, otherwise your wallet would have the final say.
I know Wayne at Rapide does a good hub for a reasonable price.
Trawl the classifieds, I bought a complete 26inch wheelset and scavenged the hubs. Ended up costing me R100 for a SLX front and Superstar evo rear.
  • 5 weeks later...
  • 6 months later...
  • 1 month later...
Reviving a thread here.
Ā
Just did this on my trance, ended up using the shimano axle mentioned on the first page. Wanted the giant / dt Swiss axle, but the shimano one does the job.
Ā
It was 800 bux from mike's bikes.
