Hub bearing specs
Headshot
Can you measure the inner diameter, outer diameter and thickness/depth? If so then replace with same size decent quality from a bearing shop or order same size Enduro bearings from your LBS. Enduro has kits for certain popular bikes and assemblies.
Most bearings have a part number moulded into the rubber seal...clean the grease off and check.
You could also try the archive section of Giant's website and look up your wheel/ bike there.
