they work on a different ratio I think <?: prefix = v ns = "urn:schemas-microsoft-com:vml" /><?: prefix = o ns = "urn:schemas-microsoft-com:office:office" /> Confused thats why they are not compatible I am running Xo gripshift with my Xo derailler. I know there are certain Sram shifters that work with Shimano deraillers but not the other way round.
Goldmember2008-04-29 13:36:49
sram works on a 1:1 ratio.  shimano is 1:2.
basically uve got to pull twice as much cable to get the sram derailleur the same distance as the shimano derailleur.
I use SRAM Rocket Twisters (Exact same as X9 Xo tiwsters) on Shimano. The rocket's ratio is different and distances between each click at the shifter is much shorter than the normal sram twisters. After feeling the new shimano operate I'm not so sure about twisters anymore. But the rocket's have been performing well on my shimano ders.
Guest Big H
Would you like a Toyota with a Ford motor..... no I do not think so. Why downgrade by mixing in Sram. Shimano groupsets especially the new XT and XT Shadowline ranges are worldclass and may weigh slightly more than XTR but is even more dependable than XTR itself. Bicycle manufscturers sometimes confuses the issue by mixing the groupsets but it is purely a financial issue regarding the OEM deals they make.
Guest Big H
Yes, but what will you do about the oil leaking onto your garage floor...... oil your chain with it?????????
You need only two tools. WD-40 and duct tape. If it doesn't move and it should' date=' use WD-40. If it moves and shouldn't, use the tape.
And if that fails get out the big gun - i.e. the welder LOL
hey this might sound petty' date=' but can you run a SRAM x0 rear derailler with a shimano chain, shimano LX shifters and shimano cassette?
Yes and no:
- you need SRAM shifters for a SRAM X0 rear derailleur. Apparently Shimano has a
  different "throw" on the levers to SRAM (some Shimano shifters might work);
- you can use SRAM shifters for a Shimano front derailleur;
- you can use a Shimano (or SRAM) chain and cassette interchangeably.
I have XTR front and X0 rear using Shimano chains and either SRAM or Shimano
cassettes. My shifters are both SRAM X0.
BTW, you can also use Shimano discs with Avid (SRAM) hydraulic brakes.
But as said before you can NOT mix the rear derailure with the shifters . Front setup you can very much do what you like as we seen last week !!! (roadie derailures) Chains , blades and cassettes also does not make a diffirence
Here we have it:
"Question:
Can I use the
SRAM X.0 Rear Derailleur with
Shimano shifters?
Answer:
No, the SRAM X.0
Rear Derailleur uses Sram?s
proprietary ESP 1:1 ratio. This
means that for each millimeter of
cable moved in the shifter, an equal
millimeter will be moved in the
derailleur. This allows a greater
acceptance of off-road conditions
(dirt, water, sand, etc.) and also
gives SRAM a unique shifting
technology. Conversely, Shimano uses
a 2:1 ratio for it's shifting
systems. This means that for every
one millimeter of movement in the
cable there will be two millimeters
of corresponding movement in the
rear derailleur. The ratios are not
the same; therefore, you cannot use
an ESP shifter and a Shimano
derailleur, or vice versa."
However, SRAM do sell shifters that will work with XTR (1:2 ratio).
