10 speed derailleur on 9 speed cassette
Frana17
You can use a sram shifter with a shimano 10spd der and 9spd cassette.  You will need to put a shim in.  Do a search.  Most recommend 6mm, I found a 10mm to be best (X7 shifter, XT 10spd der, 12-34 cassette).  Sharp and crisp - best of both worlds.
The shimano pull is not quite 1:1 - therefore the need for the shim
Edit - this is for a mountain bike only (for clarity)
Thanks so much for all the reply's much appreciated! I helped him today and managed to fix his old derailleur completely turns out it was only the cage that was bent.
No amount of tweaking will make it work - despite what a few people have said here. The pull ratios are different. The end.
Glad to hear you got it sorted though.
